Ajuda URGENTE sem luz de stop, Vag com
Boas malta
Estou sem luzes de stop é com a luz no quadrante fixa de "resistencia"
Já andei a ver os fusiveis mas parecem todos ok
Precisava da vossa ajuda para saber o que se passa. Tenho alguns erros mas o mais importante ...
VAG-COM Version: Release 311.2-N
Control Module Part Number: 6L0 035 156
Component and/or Version: seat s04 GRO 1 88
Software Coding: 00401
Work Shop Code: WSC 82504
3 Faults Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
00853 - Shareware Version. To Decode all DTCs
36-10 - Please Register/Activate - Intermittent
00856 - Shareware Version. To Decode all DTCs
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Controller: 038 906 019 DQ
Component: 1,9l R4 EDC 0650SG 1536
Coding: 00005
Shop #: WSC 00078
2 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V20
Coding: 00188
Shop #: WSC 06403
1 Fault Found:
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
Address 08 -------------------------------------------------------
Controller: 6L0 820 043 A
Component: CLIMAtronic PQ24 0201
Coding: 0000000
Shop #: WSC 00000
2 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - - - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00140
Shop #: WSC 06402
6 Faults Found:
00903 - Fuse for Heated Outside Mirrors (S196)
37-10 - Faulty - Intermittent
01598 - Drive Battery Voltage
27-10 - Implausible Signal - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01317 - Control Module in Instrument Cluster (J285)
00906 - Horn (H1)
28-10 - Short to B+ - Intermittent
07-10 - Signal to Low - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 830 K
Component: KOMBI+WEGFAHRSP TRW V02
Coding: 00146
Shop #: WSC 00000
VSSZZZ6LZ3R118403 SEZAZ0B3160085
1 Fault Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 60 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06402
2 Faults Found:
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00171
Shop #: WSC 06402
No fault code found.
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 2G Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
2 Faults Found:
00928 - Locking Module for Central Locking: Front Driver Side (F220)
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
Address 56 -------------------------------------------------------
Controller: 6L0 035 156
Component: seat s04 GRO 1 88
Coding: 00401
Shop #: WSC 82504
3 Faults Found:
00853 - Loudspeaker(s): Rear
00856 - Radio Antenna
End -------------------------------------------------------
Alguem me pode dar uma ajuda urgente? Amanha vai para oficina pois considero grave andar sem luzes de stop!!
Abrc
eu no meu 6k o problema éra no pedal tem la uma pecinha de plastico e a molinha de dentro tinha pouca força, o que nao acendia os stpos
o problema foi resolvido com uma mola de uma caneta
Amigo... Podera ser brake switch...
E uma peça(válvula) atras do pedal de travao de pe... onde liga uma ficha...
Eu tenho o mesmo problema, travo e não dá a luz dos 3 stop's, e o tal sinal da resistência está sempre a piscar, e também liga o ABS e o ESP no quadrante ...
E essa pecinha é o suficiente para criar erro no vag com e aparecer no quadrante? Os outros erros eu ja percebi que tenho, coluna do som do lado do pendura está meia marada, quadrante está com problems 6mostradores o cancro dos quadrantes, bateria parece ja ter sintomas de estar fraca, liga me a luz de direçao quando ligo o carro de manha, pelo que li no forum espanhol é a bateria fraca e lá está o erro no vag com..and so on...lol
Será caro o arranjo ? Em prencipio amanha fica na oficina pq tenho de fazer a revisao...quero estar a contar com o vou ter de €€
exatamente amigos isso e uma valvula ke fica por cima do pedal de tavao,sem duvida....
uma valvula nova e original custa cerca de 20euros....
que seja só isso já fico feliz lol Já imprimi os erros do vag com e já levam a papinha feita na oficina
Hmm o meu tb tinha salvo erro uma ou duas lampadas fundidas mas continuava sem stop msm dp de substituidas. Tb é vdd que n tinha apagado os erros do vag com nem antes nem dp de substituidas.Na oficina deram me o switch e aparentemente tava normal, por dentro n abri a ver se tinha algo queimad, nem da pa abrir tirando a parte da mola.O prejuizo tb n foi mt 15€
A mim era o simbolo da resistencia a piscar conclusao: 2 lampadas de stop novas apagar erro no vagcom e ficou novo
no meu tenho um problema parecido, acende resistencia, travo, apaga a resistencia, ando uns pedaço acende de novo, travo apaga a luz de resistencia,, ta td a funcionar normal...o brake switch ja foi aberto nova mola e limpo os contatos...
aconteceu me o mesmo e era a tal valvula!!!
isso é barato, mas se keres um conxelho caso seja esse o problema mete uma original pois as de concorrencia vao a vida mto mais facilmente!!!
cmps
