Address 08 -------------------------------------------------------
Controller: 6L0 820 043 B
Component: CLIMAtronic PQ24 0201
Coding: 0000000
Shop #: WSC 00000
3 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
000 - - - Intermittent
01273 - Fresh Air Blower (V2)
00792 - A/C Pressure Switch (F129)
000 - -
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00140
Shop #: WSC 06402
2 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01598 - Drive Battery Voltage
07-00 - Signal to Low
Address 17 -------------------------------------------------------
Controller: 6L0 920 820 K
Component: KOMBI+WEGFAHRSP VDO V12
Coding: 00145
Shop #: WSC 00000
VSSZZZ6LZ4R167344 SEZ7Z0D2369432
1 Fault Found:
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 0060 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
1 Fault Found:
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10181
Shop #: WSC 06402
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 01 Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
2 Faults Found:
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
Coding: 0000000
Shop #: WSC 00000
3 Faults Found:
000 - -
Coding: 00140
Shop #: WSC 06402
2 Faults Found:
Coding: 00145
Shop #: WSC 00000
1 Fault Found:
Coding: 00014
Shop #: WSC 06402
1 Fault Found:
Coding: 10181
Shop #: WSC 06402
1 Fault Found:
Coding: 00064
Shop #: WSC 06402
2 Faults Found:
