Erros atrás de erros , ibiza 6L. Ajuda! :S
Boas malta... decidi fazer um check a ver como estava a maquina.. resultado, 14 erros :shock::shock:
Alguem me sabe dizer o que se passa? eis os erros:
VAG-COM Version: Release 303.1
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,44,46,56,69
Controller: 038 906 019 NJ
Component: G000SG 7331
Coding: 00105
Shop #: WSC 06402
VSSZZZ6LZ7R159907 SEZ7Z0G3717221
5 Faults Found:
19558 - Motor for Intake Manifold Flap (V157): No Signal
P3102 - 35-00 - -
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101 - 35-10 - - - Intermittent
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-00 - -
17054 - Glow Plug Module 1: Electrical Malfunction
P0670 - 35-00 - -
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller:
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 08 -------------------------------------------------------
Controller: 6L0 820 043 E
Component: CLIMAtronic PQ24 3805
Coding: 0000000
Shop #: WSC 00000
1 Faults Found:
00792 - A/C Pressure Switch (F129)
000 - -
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 F
Component: 000B BN-SG. 2S36
Coding: 08332
Shop #: WSC 06402
2 Faults Found:
49-10 - No Communications - Intermittent
01598 - Drive Battery Voltage
07-10 - Signal to Low - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 823 H
Component: KOMBIINSTRUMENT VDO V02
Coding: 00105
Shop #: WSC 00000
1 Faults Found:
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 02QT GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
1 Faults Found:
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 06402
1 Faults Found:
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00016
Shop #: WSC 06402
1 Faults Found:
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
Address 56 -------------------------------------------------------
Controller: 6L0 035 186 C
Component: seat s04 GRO 6 37
Coding: 00401
Shop #: WSC 06402
0 Faults Found:
End -------------------------------------------------------
Faz o k o Pedro disse ;-)
Aqui tens a lista :D
00532
Localização da avaria - Módulo de controlo do motor
tensão de alimentação
Causa provável - Fusível, alternador, bateria, tomada de
corrente com a ignição DESLIGADA, relé
de controlo do motor, cablagem
00792
Localização da avaria - Interruptor de pressão do ar
condicionado
Causa provável - Cablagem, interruptor de pressão do ar
condicionado
01314
Localização da avaria - Módulo de controlo do motor,
sistema de controlo da velocidade
cruzeiro - defeituoso
Causa provável - Módulo de controlo do motor
17054
Localização da avaria - Módulo de controlo das velas de
incandescência - avaria no circuito
Causa provável - Cablagem, má ligação, módulo de controlo
das velas de incandescência
17552
Localização da avaria - Sensor de medição do fluxo de ar,
banco 1 - circuito aberto/curtocircuito
à massa
Causa provável - Circuito aberto na cablagem/curto-circuito à
massa, sensor de medição do fluxo de ar
17964
Localização da avaria - Pressão do turbocompressor -
limite de controlo não atingido
Causa provável - Válvula reguladora da descarga do
turbocompressor, fuga na admissão,
turbocompressor avariado
19557
Localização da avaria - Actuador do controlo do ar do
colector de admissão - curto circuito
à massa
Causa provável - Curto-circuito à massa na cablagem,
actuador do controlo do ar do colector de
admissão
19558
colector de admissão - ausência
de sinal
Causa provável - Circuito aberto na cablagem, actuador do
controlo do ar do colector de admissão
Ora bem, neste momento ja so tenho 9/10 erros lololol
os que consegui resolver foram o do Desvio e massa de ar.
Continuo com o problema das velas, relé trocado e mesmo assim nada :|
Tambem continuo a patinar nos erros todos que aparecem como Intermitentes, bateria tem mais 10A que a original, contudo tenho a bateria na bagageira, será disso?
amigo ja testas-te as velas ca fora?
existem ai alguns erros que tal como falamos dão mesmo a ideia de algo no sitema electrico não estar a 100%
confirma os valores que chegam a frente do carro amigo.
ah e confirma se terá todos os pontos de massa bons.
o problema poderá estar mesmo ai ;)
00532
00792
condicionado
condicionado
01314
17054
17552
à massa
17964
19557
à massa
admissão
19558
de sinal
Boa tarde,
Onde da para esta informação, qual o programa?
hehe era nice ser descartavel a esse ponto..
Sim ja testei cá fora, o problema é que nao chega ponta de corrente ao cachimbo das velas, o rele ja foi trocado tb...
Sim irei rever todos os pontos de massa a ver se resolve ou nao, pelo menos esses erros da treta intermitens :S
Alguns do erros parecem suspeitos.
Tens xenon aftermark no carro?
Repro?
Ja apagast os erros e voltast a fazer scan?
Repro?
boas, sim tenho xenon aftermark em maximos(medios xenon oem)
Repro ja tive, mas tirei e pus file original ate resolver todos os stresses...
Sim ja apaguei mais de 10x pois em testes a ver se pode ser de algum sitio...
