Boas malta precisava da vossa ajuda;
tenho um 6L 1.2 a gasolina de 2004 e de à cerca de 2 meses para ca tem me acendido a luz de direçao, o estranho é k desligo o carro e volto a ligar e a luz ja n acende. se o carro ficar parado/desligado mais de 15 minutos quando o volto a ligar lá fica a luz da direçao novamente ligada, ja liguei o vag-com e apareceu me estes erros;
Tuesday,13,February,2018,17:52:04:53651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
www.Ross-Tech.com
VIN: VSSZZZ6LZ4R163290 License Plate:
Chassis Type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ4R163290 Mileage: 135590km-84251miles
Address 01: Engine Labels: 03E-906-033-AZQ.lbl
Part No: 03E 906 033 P
Component: 1.2l/4V SIMOS3 00HS4729
Coding: 00071
Shop #: WSC 06402
VCID: 2D516F91E7C0AD2954-5140
VSSZZZ6LZ4R163290 SEZ7Z0D2369207
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.lbl
Part No: 6Q0 907 379 G
Component: ABS 5.7 FRONT V40
Coding: 00044
Shop #: WSC 06403
VCID: 418923214B58594980-5140
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 B
Component: CLIMAtronic PQ24 0301
Shop #: WSC 00000 000 00000
VCID: 254197B1EF3095699C-5140
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 16524
Shop #: WSC 06402
VCID: 3C7752D52CBA34A1D3-515E
1 Fault Found:
00778 - Steering Angle Sensor (G85)
49-00 - No Communications
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AE
Component: 0E AIRBAG VW5 07 0009
Coding: 12357
Shop #: WSC 06401
VCID: 7AFB94CD660ECA9181-5140
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 820 F
Component: KOMBI+WEGFAHRSP VDO V12
Coding: 00135
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0061 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
VCID: 70EFB6E5307280C13F-515E
1 Fault Found:
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10111
Shop #: WSC 06402
VCID: 6FEDB5992D4C9F3926-5140
1 Fault Found:
00816 - Power Steering Sensor (G250)
30-10 - Open or Short to Plus - Intermittent
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: J1 Komfortgerát 0002
Coding: 00258
Shop #: WSC 06402
VCID: 3D715FD137A03DA9E4-4B00
Subsystem 1 - Part No: 6Q2959802A
Component: J1 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 6Q2959801A
Component: J1 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 6Q0959811A
Component: J1 Tõrsteuer.HL KLO 0203
Subsystem 4 - Part No: 6Q0959812A
Component: J1 Tõrsteuer.HR KLO 0203
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
End-------------------------(Elapsed Time: 03:14)--------------------------
Digam as vossas opinioes, obrigado malta
www.Ross-Tech.com
Coding: 00071
Shop #: WSC 06402
Coding: 00044
Shop #: WSC 06403
Coding: 16524
Shop #: WSC 06402
1 Fault Found:
Coding: 12357
Shop #: WSC 06401
Coding: 00135
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 06402
1 Fault Found:
Coding: 10111
Shop #: WSC 06402
1 Fault Found:
Coding: 00258
Shop #: WSC 06402
1 Fault Found:
