Guia VAG-COM
ja agora pessoal ja andei a procura mas nao encontrei sera que me podiam dizer como se vê se o ponto de motor esta de origem através do VAG COnas ??? obrigado :D
fiz novo teste depois de ter apagado os erros, e continuaram estes erros:
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 056 AA HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 2898
Revision: --H08--- Serial number: SEX7Z0H531A0G8
Coding: 0050071
Shop #: WSC 06402 785 00200
2 Faults Found
013112 - Control Circuit for Glow Plug Controller 1: Electrical Malfunction
P3338 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Mileage: 52987 km
Time Indication: 0
Date: 2000.00.00
Time: 20:27:43
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Temperature: 15.3°C
Bin. Bits: 01010000
005441 - Fuel Pump Relay (J17): Open Circuit
P1541 - 000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 52987 km
Time Indication: 0
Date: 2000.00.00
Time: 20:27:44
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Bin. Bits: 0
(no units): 0.0
Readiness: 0 0 0 0 1
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000005777589
Coding: 41880F2F00041000431D00000000000000017F075C400000000000000000
Part No: 1P0 955 559
Component: REGENLICHTSENSORH04 0090
Coding: 00152622
Shop #: WSC 06402
Component: Fehler Lin-Slave 01
2 Faults Found
02071 - Local Databus
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 52987 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 52987 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
OFF
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000003488504
Coding: 0004272
1 Fault Found
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 52987 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.077 H08 1901
1 Fault Found
00778 - Steering Angle Sensor (G85)
000 - -
alguem me pode ajudar?
Coding: 0050071
2 Faults Found
P3338 - 000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Mileage: 52987 km
Time Indication: 0
Date: 2000.00.00
Time: 20:27:43
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Temperature: 15.3°C
Bin. Bits: 01010000
P1541 - 000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 52987 km
Time Indication: 0
Date: 2000.00.00
Time: 20:27:44
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Bin. Bits: 0
(no units): 0.0
Coding: 00152622
Shop #: WSC 06402
2 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 52987 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 52987 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
OFF
Coding: 0004272
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 52987 km
Time Indication: 0
1 Fault Found
000 - -
xi ca ganda lista iss ta td fdd lol se soubesse ajudava-te mas num percebo um caraças disto
P1541 - 000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 52987 km
Time Indication: 0
Date: 2000.00.00
Time: 20:27:44
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Bin. Bits: 0
(no units): 0.0
Realmente são muitas avarias, mas esta parece ser fácil...
Podes ver o que se passa com o relé J17, poderá ser maus contactos ou bobine queimada!!!!
1º peço desculpa se for "repost" mas não encontrei.
Existe um site de erros do VAG-COM http://wiki.ross-tech.com/index.php/Category:Fault_Codes que me é bastante útil, já me desenrascou várias vezes com um A3 de 1997, é pena não ser actualizado constantemente, mas tem uma grande quantidade de erros, as suas causas, os sintomas, e como os reparar, ATENÇÃO que são apenas informações. Devemos ler sempre tudo, pois já me aconteceu que um erro era reparado de uma maneira, mas o mesmo erro em conjunto com outro já era de outra.
Espero que seja útil.
Boas pessoal.
Tenho uma dúvida. normalmente utilizam o vag-com com o motor ligado? ou só dando à chave até o painel de instrumentos ficar ligado?
obrigado
ontem fiquei sem direcçao assistida... o erro que aparece é este:
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10181
Shop #: WSC 06402
1 Fault Found:
01288 - Terminal 30: Steering Assist
06-10 - Signal to High - Intermittent
podem ajudar? foi um cagaço em plena ae
Bom dia, já li algures como se faz para anular a EGR através do Vag. Mas tenho uma questão, essa alteração é feita com o motor a trabalhar ou nem por isso? É que já tentei fazer e depois de por o código ele não passa daí.
Abraxo...
