pega mal a frio e a quente
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Controller: 038 906 019 NF
Component: 1,9l R4 EDC G000SG 7000
Coding: 00102
Shop #: WSC 06402
No fault code found.
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 T
Component: ESP 8.0 front H03 0002
Coding: 0000290
Shop #: WSC 06403
Address 08 -------------------------------------------------------
Controller: 6L0 820 043 B
Component: CLIMAtronic PQ24 0301
Coding: 0000000
Shop #: WSC 00000
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 820 P
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 00145
Shop #: WSC 00000
1 Fault Found:
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 0068 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
1 Fault Found:
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 06402
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 0R Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
Address 56 -------------------------------------------------------
Controller: 6L0 035 156 B
Component: seat s04 GRO 3 99
Coding: 00401
Shop #: WSC 06402
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------------
o carro da estes erros será que alguem me pode ajudar?
boas pessoal
eu como trabalho a mecanico e ja me apareceram muitos probblemas desses, vou dara minha opiniao e espero ser util.. nuno, no teu caso, deve ser algum tubo de gasolio deposito-bomba que deve tar a deixar entrar ar, e como o carro para durante alguns minutos, o gasolio recua, depois demora mais a chegar a bomba.... normalmente e um t que leva em cima do filtro de gasolio que deve ter o vedante lixado... mas nunca e demais verificar as velas... caso o problema n seja dai, aconselo te a verificar, o rele das velas, as velas e mesmo o motor de arranque... acontece mt nos motores tdi pegarem mal a frio e ser o motor de arranque... falo por carros que ja passaram na minha mao.... espero ter sido util...
abraco
Problema resolvido a bateria estava maluca troquei e ja esta bom pega bem normalmente. Como novo :clap:
